Fabrucation spool schedule
Hello dynamo community, i am working in a spool script with tool.Assemblyviews node. The output schedule is only came partlist instead of fabrication pipework schedule. i dont know how to edit and rewrite the script the python script inside this node.if anyone the solution please help me out this thank you.
this is th script
Developers nodes in dynamo 1.0
#proposed by Julien Benoit @jbenoit44
#http://aecuandme.wordpress.com/
Import ToDSType(bool) extension method
Import geometry conversion extension methods
Import DocumentManager and TransactionManager
Import RevitAPI
clr.AddReference(“RevitAPI”)
app = uiapp.Application
elt =
for i in IN[0]:
elt.append(UnwrapElement(i).Id)
tb=UnwrapElement(IN[13]).Id
catid=doc.GetElement(elt[0]).Category.Id
collection=ListElementId
viewlist=
schedlist=
sheetlist=
Start Transaction
for a in elt:
views=
if IN[1] == 1:
v=AssemblyViewUtils.Create3DOrthographic(doc,a)
views.append(v)
if IN[2] == 1:
ds2=AssemblyViewUtils.CreateDetailSection(doc,a,AssemblyDetailViewOrientation.HorizontalDetail)
views.append(ds2)
if IN[3] == 1:
ds3=AssemblyViewUtils.CreateDetailSection(doc,a,AssemblyDetailViewOrientation.ElevationTop)
views.append(ds3)
if IN[4] == 1:
ds4=AssemblyViewUtils.CreateDetailSection(doc,a,AssemblyDetailViewOrientation.ElevationBottom)
views.append(ds4)
if IN[5] == 1:
ds5=AssemblyViewUtils.CreateDetailSection(doc,a,AssemblyDetailViewOrientation.ElevationLeft)
views.append(ds5)
if IN[6] == 1:
ds6=AssemblyViewUtils.CreateDetailSection(doc,a,AssemblyDetailViewOrientation.ElevationRight)
views.append(ds6)
if IN[7] == 1:
ds7=AssemblyViewUtils.CreateDetailSection(doc,a,AssemblyDetailViewOrientation.ElevationFront)
views.append(ds7)
if IN[8] == 1:
ds8=AssemblyViewUtils.CreateDetailSection(doc,a,AssemblyDetailViewOrientation.ElevationBack)
views.append(ds8)
if IN[9] == 1:
ds9=AssemblyViewUtils.CreatePartList(doc,a)
views.append(ds9)
if IN[10] == 1:
ds10=AssemblyViewUtils.CreateDetailSection(doc,a,AssemblyDetailViewOrientation.DetailSectionA)
views.append(ds10)
if IN[11] == 1:
ds11=AssemblyViewUtils.CreateDetailSection(doc,a,AssemblyDetailViewOrientation.DetailSectionB)
views.append(ds11)
viewlist.append(views)
if IN[12] == 1:
sh=AssemblyViewUtils.CreateSheet(doc,a,tb)
for v in views:
if Viewport.CanAddViewToSheet(doc,sh.Id,v.Id) == 1:
Viewport.Create(doc,sh.Id,v.Id,XYZ(0,0,0))
ScheduleSheetInstance.Create(doc,sh.Id,v.Id,XYZ(0,0,0))
sheetlist.append(sh)
doc.Regenerate()
End Transaction
OUT=viewlist,sheetlist
Hi @bim6MRER3 you could add that schedule to your assembly sheet if that you mean :wink:
no sir,in spool sheet schedule automatically add in spool generating the spool sheet, but the schedule category is partlist.i need mep fabrication schedule instead of partlist in automatic sheet gen
i try this but entire schedule add in a sheet, but i need those assembly parts schedule only sir
allright not sure that is possible…if i understand :wink:
thank you sir
this looks interesting. fire protection in revit, need Help?
Revit Simple Sprinkler 3D Branch Tool Update | Streamlining Fire Protection Documentation
try creating a schedule template first, duplicate each schedule on each sheet. set schedule by View.
