Im trying to do changes in penetration sleeve height/width/thickness and offset with respect to duct size.(family name for penetration sleeve = family 1 )
Hi Nissal,
I was the one that created the Walls Pipes intersection script (with much guidance).
I tried opening your model and script. It appears that you are using Dynamo 2.0. I initially built it in 1.3 due to stability issues, and that’s exactly what I’m experiencing with yours. I get a hard crash every time I try to open your script. It may be due to one or more of the packages that were upgraded (Bakery and Clockwork), so I can’t even troubleshoot it. I could try swapping out the nodes with others from different packages, but right now I can’t even open your script. I tried opening your script in 1.3 but it gave me a corrupt file error.
Try rebuilding with 1.3 and see if you get the same results.
