Get Type from FamilySymbol
Hi Everyone . I’m trying to get the Type Name from Family Symbol but the result is an empty list. Is there a way I can get the Type “300 x 600mm” from a list of 2 types (0 List)? Please help me. Thanks everyone…!
import System
clr.AddReference("ProtoGeometry")
clr.AddReference("RevitAPI")
view = doc.ActiveView
filterframing = FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_StructuralFraming).WhereElementIsElementType().ToElements()
framingUse = []
for i in filterframing:
    if i.Family.Name == "M_Concrete-Rectangular Beam" :
        framingUse.append(i)
typeframing = []
for i in framingUse:
    if i.GetType().ToString() == "300 x 600mm":
        typeframing.append(i)
OUT = framingUse,typeframing
Help me
Hi @bimtechgts
To get the name of a Family Type, you can use the BuiltInParameters
000156
import System
#Get all the Family Types (Family Symbols in the Project)
allFramingTypesInProject = FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_StructuralFraming).WhereElementIsElementType().ToElements()
framingTypeNames = []
params = []
for type in allFramingTypesInProject:
	#Get the Family Type Name Parameter
	parameter = type.get_Parameter(BuiltInParameter.SYMBOL_NAME_PARAM)
	#Get the Value of the Parameter --> The Name
	typeName = parameter.AsString()
	#Add the Name to the Output List
	framingTypeNames.append(typeName)
OUT = allFramingTypesInProject, framingTypeNames
I don’t believe GetType() is a valid method. Plus, your list is already of the FamilySymbols, you just need to get the name from them at that point (as you can see in @Joelmick’s code).
