Is there a better way to get dynamo geometry of a Tin Surface as a solid? I am using this sequence of nodes…
goal is to obtain solid geometry in dynamo so I can perform earthwork analysis with Boolean subtraction between various solids.
topsoil volumes
cut
fill
import/export
etc
Maybe another way to ask the question is…
Is it possible to create a dynamo solid from TIN SURFACE using the Mesh Toolkit? I have attempted and failed.
Curious if anyone else has had success?
But you still look for a workflow to create the solid for Volume quantification?
Correct.
I am able to create solids and compute earthwork volumes using the TinSurface.Extensions.CreateSolids node (as per your example).
However, this workflow takes a very long time to execute when working with larger surfaces.
So I am curious if there is a workflow that derives solid geometry from this node (or any other)…
Autodesk TinSurfaceExtensions.GetMesh
