Tin surface Edit
Hello everyone,
I can’t edit a surface imported with LandXML. For example, I’m creating Python code to set the maximum side length of a triangle to 10 m, but nothing changes on the Civil 3D screen. How do I create the Python script? Can you help me?
clr.AddReference(‘AeccDbMgd’)
clr.AddReference(‘AutoCADMgd’)
doc = Application.DocumentManager.MdiActiveDocument
db = doc.Database
input_surface = IN[0]
max_length = 10.0 # 10 meters
with doc.LockDocument():
with db.TransactionManager.StartTransaction() as trans:
    surface = trans.GetObject(input_surface.Id, OpenMode.ForWrite)
    build_properties = surface.BuildProperties
    build_properties.UseMaximumTriangleLength = True
    build_properties.MaximumTriangleLength = max_length
    surface.Rebuild()
    trans.Commit()
doc.Editor.Regen()
Hi @tugrul.koksalPUUYK ,
try this:
#AutoCAD assemblies
clr.AddReference('AcMgd')
clr.AddReference('AcDbMgd')
clr.AddReference('AeccDbMgd')
#AutoCAD namespaces
fromAutodesk.AutoCAD.ApplicationServicesimport *
fromAutodesk.AutoCAD.DatabaseServicesimport *
#Civil 3D namespaces
fromAutodesk.Civil.DatabaseServicesimport *
fromAutodesk.Civil.ApplicationServicesimport *
#Get active AutoCAD document
def update_surface_length(c3d_surface, length):
global adoc
# Check input values
ifc3d_surfaceisNoneorlengthis None:
return c3d_surface
# Lock the active document
with adoc.LockDocument():
# Start database transaction
with adoc.Databaseas db:
# Get ObjectId from the Civil 3D surface element
surface_id = c3d_surface.InternalObjectId
# Open the surface for writing
civil_surface = trans.GetObject(surface_id,OpenMode.ForWrite)
# Check that the object is a Civil 3D Surface
if isinstance(civil_surface, Surface):
# Get surface build options
build_options = civil_surface.BuildOptions
# Enable maximum triangle length
build_options.UseMaximumTriangleLength = True
# Set maximum triangle length
build_options.MaximumTriangleLength =float(length)
# Rebuild the surface
civil_surface.Rebuild()
# Commit changes
trans.Commit()
return c3d_surface
#Inputs:
Civil_3D_Surface = IN[0]
Triangle_Length = IN[1]
OUT = update_surface_length(Civil_3D_Surface, Triangle_Length)
Hello. I’m unsure which components to use for my Dynamo monitor. Can you help me?
