I am currently using Dynamo Generative Design with Civil 3D.
At the moment, the Dynamo program I created runs successfully, and I am also able to generate Case Studies successfully in Generative Design.
After selecting the desired Case Study, I launch Dynamo again to use the inputs from that case to generate a model in Civil 3D.
However, I am facing an issue: although the Case Study runs successfully and all geometries are displayed as expected, when I select a Case Study and run Dynamo, the data from nodes where I use Select Objects to directly select solids in Civil 3D cannot be read.
The Select Objects node still displays the Object ID, but the Object.Geometry and Remember nodes return Null.
I apologize for not being able to share my working files due to confidentiality reasons.
Instead, I am providing a reference document that includes the node I am using.
The attached image is for illustration purposes.
If you have any experience with this issue, I would greatly appreciate your insight into the possible cause.
Thank you very much.
Mesh_2ptDistance.dyn (3.4 MB)
Test.dwg (1.8 MB)
