I try to get the reference alignment name for each pressure pipe object in a pressure pipe network, the model contains serval alignments, therefore I create a preliminary dynamo script as the following, but I stop at the point where I don’t know how to continue?
The fastest way is to make your script to manually select the alignment and the pressure parts needed to be referenced to that alignment.
I install “Camber” of dynamo for civil 3D and create a dynamo script with camber node in order to extract pressure pipe parts with associated alignments and export to Excel, but the excel file does not shown desired information,.
Hi
Could you zoom in so that you see the names of the nodes and then use Dynamos function to create a screenshot of the canvas and upload that instead?
For the moment we can’t see the name of the nodes.
And collapse the List.Create node just before the excel node.
Dear Patrick,
Thanks for your kind reply, the files for the probllem are as attached.
Find PipeRun with PressurParts.dyn (37.7 KB)
Sample.dwg (4.9 MB)
Sample.xlsx (8.9 KB)
