The outputs on the nodes are modified
Hello, every time I run the dynamo from the player I create an item in the output of some nodes, someone knows what is due:
Looks like custom node package has not been updated for dynamo 2.x. Is this archi-lab package? Or may be it is conflicting with other node. Try removing other packages you have installed as a first step.
:point_up: This is absolutely the issue. This is an archilab node and is due to be fixed in the next release as indicated below.
