Hello, I have another API question. I am using Revit 2015 and Dynamo 0.9.2. How do I call a selected TextNote’s Leader’s TextNoteLeaderStyle to check if it is TextNoteLeaderStyles.LCS_TWO_SEG_LINE ? So far my script selects all TextNotes and applies the function but I want to only apply the function on TextNotes with a leader that has 2 segments.
My python script so far:
clr.AddReference('RevitAPI')
import math
# -------------------- Functions ------------------------
def vUnwrap(x): #Unwraps elements
	elements = []
	if hasattr(x, '__iter__'):
		for i in x:
			elements.append(UnwrapElement(i))
		return UnwrapElement(x)
	return elements
def vLeaders(textNote):
	textLoc = textNote.Coord
	leaderArray = textNote.Leaders		#Returns LeaderArray var
	for leader in leaderArray:	#Accesses Leader var
		leaderEnd = leader.End
		oldElbow = leader.Elbow
	textNote.RemoveLeaders()
	leaderStart = XYZ(textLoc.X,oldElbow.Y,textLoc.Z)
	yDist = leaderStart.Y - leaderEnd.Y
	if leaderStart.Y >= leaderEnd.Y and leaderStart.X <= leaderEnd.X:
		elbowX = leaderEnd.X - yDist
	elif leaderStart.Y > leaderEnd.Y and leaderStart.X > leaderEnd.X:
		elbowX = leaderEnd.X + yDist
	elif leaderStart.Y < leaderEnd.Y and leaderStart.X > leaderEnd.X:
	elbowY = leaderStart.Y
	leaderElbow = XYZ(elbowX,elbowY,leaderStart.Z)
	newLeader = textNote.AddLeader(TextNoteLeaderTypes.TNLT_STRAIGHT_R)
	newLeader.End = leaderEnd
	newLeader.Elbow = leaderElbow
	return textNote
"""def getViews(textNote, doc):
	Id = textNote.OwnerViewId
	view = doc.GetElement(Id)
	return view"""
# --------------------- Main ---------------------------
textNotes = IN[0]
#textType = textNote.TextNoteType
#textSize = textType.GetParameters('Text Size')
tnArray = []
for j in textNotes:
	textNote = vUnwrap(j)
	newText = vLeaders(textNote)
	tnArray.append(newText.ToDSType(False))
OUT = tnArray
Also if anyone could point me in the right direction on why when I apply this script on multiple TextNotes, only the final textnote in the list shows the updates in the model, but when re-opening or moving the rest of the textnotes, they show the correct update. I am thinking maybe it has to do with transactions?
