Is it possible to turn the text before " : " of each line into bold through dynamo or python? It’s a textnote…
Here is an example of the textnote
And this is how I wish it turns into…
@tiagofrbr Yes, it’s possible using this method.
Try this:
clr.AddReference('RevitAPI')
toList = lambda x : x if hasattr(x, '__iter__') else [x]
textNotes = toList(UnwrapElement(IN[0]))
OUT = []
for textNote in textNotes:
noteText = textNote.Text
if IN[1] in noteText:
end = noteText.index(IN[1])
gft = textNote.GetFormattedText()
gft.SetBoldStatus(TextRange(0,end+1), True)
textNote.SetFormattedText(gft)
OUT.append(textNote)
@tiagofrbr In that case try this: Bold.dyn (17.9 KB)
textNote = textNotes[0]
for i in IN[1][:-1]:
gft.SetBoldStatus(TextRange(i,IN[2]),True)
OUT = textNote
Python node inputs:
IN[1] : The start position of each new line
IN[2] : The number of characters you want to bold out from the start of line
Hello
another solution
import re
txt = textNote.Text
for match in re.finditer(r'PL.+?\:', txt):
lengthStr = match.end() - match.start()
gft.SetBoldStatus(TextRange(match.start() ,lengthStr),True)
OUT = txt
Both methods worked! However c.poupin your method works only for the lines that start with PL? Because I’d like a code that works with any text before " : "… If possible I also need to clear the current format of the textnote before applying the bold
it is a regular expression, you can adapt it if necessary
@tiagofrbr Try this: TextNote Formatting.dyn (11.0 KB)
#Written by Amol S + Cyril P
import re
pattern = r'^.+?'+IN[1]
if IN[2]: gft.SetAllCapsStatus(False)
if IN[3]: gft.SetBoldStatus(False)
if IN[4]: gft.SetItalicStatus(False)
if IN[5]: gft.SetUnderlineStatus(False)
txt = textNote.Text
reTxt = txt.replace("\r","\n").replace("\r\n","\n")
for match in re.finditer(pattern,reTxt,re.M):
gft.SetBoldStatus(TextRange(match.start(),lengthStr),True)
OUT = IN[0]
@tiagofrbr Try this: TextNoteFormatting.dyn (12.4 KB)
import re
if IN[6]:
textRange = gft.AsTextRange()
gft.SetListType(textRange,ListType.Bullet)
txt = textNote.Text
OUT = IN[0]
Amazing it worked! Thanks AmolShah!
AmolShah actually I realized that another problem happens sometimes. When the node TextNote.SetText is connected to the Select.element node all the text gets bold and it doesn’t work as expected. Do you know why?
@tiagofrbr Connect the output of TextNote.SetText node to IN[7] input of Python node.
This way you make sure that the text is set first and then it’s being formatted by the Python node.
