Tessellation on Face
Hi everyone,
I have just started to use Dynamo and I’m trying to make a tessellation on the face of a conceptual mass, but the lines created by the tessellation node don’t conform to the edges of the mass.
I’m just wondering how I can make the lines conform to the face of the mass? Should there be another node in there?
Matt
Thanks very much Vikram, seems to be working fine now.
Thank you Vikram for your illustration. I have a set of coordinates that seem to be magnified as they are put into the Voronoi node.
Would you have any idea why this is happening? Thank you~!
Ok, I’m beginning to understand how much I don’t understand about UV vs Points. It seems that they are different things.
I hope that means that you now understand that a UV coordinate would have a min value of 0 and a max value of 1
For example, if we consider a rectangular surface. (0,0) would be a point at the bottom left corner, (1,1) would be a point at the top right corner, (0.5,0.5) would be a point at the center of the surface and so on…
