I’m am trying to get a temperature parameter and the units are no longer in Kelvin.
0 deg F = 0.997829248702976
1 def F = 1
42 deg F = 1.08900080317798
54 deg F = 1.11504981874227
Anyone know what the new units are in Dynamo? Need to get this in Fahrenheit so I can do calculations.
Hi @bmsewell,
You can use Springs.Element.GetParameterUnitValue node or GetParameterAsProjectUnits node to get the correct value in Farenheit.
For some reason, the GetParameterUnitValue function is not working.
The value in Revit I’m trying to get is 80 deg F, which appears as 1.171… when using GetParameterValueByName.
Can you post an RVT (or a link to such) with only one element in it, and a temperature parmeter that reports this way?
