Tag Re-Run Deletion, Dynamo Owned?
I made a little graph to tag elements in view which filters down the elements… The default Revit does every element of a category.
The only problem with the graph is that if i want to tag something else, the previously created tags are deleted.
I presume this is because the tags are still Dynamo owned and I need them to be Revit owned? The Tag node is OOTB so i can’t see what’s going on in there, I tried making a Python to convert it but got an error…
Any suggestions gratefully received!
Mark
TagCurrentView.dyn (42.6 KB)
tag = UnwrapElement(IN[0])
OUT = [tag.ToDSType(True), #Not created in script, mark as Revit-owned
Hi :slight_smile:
I do not really know anything about Tags, but your Python Script may be bugging because you are missing a closing bracket at the end of the output
OUT = [tag.ToDSType(True)], #Not created in script, mark as Revit-owned
Hah, thanks!
I’ve updated and tweaked and it works! (So far)
Would you know how to get my output working? I can’t get my head around what tel is == to…
Mark
output = []
tel = []
for t in tag:
    tel = t.ToDSType(True), #Not created in script, mark as Revit-owned
    if tell == True:
        output ="Success"
        output = "Fail"
OUT = output, tel
Hi @Mark.Ackerley
Use archi-lab Create annotation tag instead you will feel the difference :slight_smile:
Awesome, thanks, that’s an education!
Again, i do not know anything about tags, but that is my guess if you are trying to correct your Python Script :slight_smile:
output = []
tel = []
for t in tag:
	inter = t.ToDSType(True)
	tel.append(inter)
	if inter:
		output.append("Success")
		output.append("Fail")
OUT = output, tel
Boom! Thanks for that :slight_smile:
