Synchronizing Geometry Generated in Dynamo with Revit
I’m following along with a Lynda tutorial:
https://www.lynda.com/Revit-tutorials/Dynamo-Revit-Workflow/494383-2.html
And I’m having trouble getting geometry generated in Dynamo to appear/sync in Revit as it did in the tutorial. I even tried adding an importinstance.bygeometry node to manually import it into Revit and still no luck. I also checked Visibility/Graphics in Revit and made sure all boxes were checked. I still can’t get the blue lines to appear in Revit. Any guidance on how to achieve this is greatly appreciated. Thanks!
3_02_ListLacing_DTran.dyn (315.9 KB)
Make sure your back ground preview is enabled.
View → backround 3d Preivew
yes! thank you Jacob!
