Switching between 2d and 3d extent (Levels, Grid)
Is it possible to switch grid extent from 2d to 3d and vice versa in revit through dynamo? I am not sure the Revit API allows that but i want to confirm.
Kia ora,
With the help of Python and only if you’re using Revit 2016 or higher… Try changing the category to Grids - I got this to work with levels extents and believe they work the same way (ViewSpecific=2D and Model=3D).
clr.AddReference('RevitAPI')
app = uiapp.Application
a = UnwrapElement(IN[0])
v = UnwrapElement(IN[1])
for i in a:
#    i.SetDatumExtentType(DatumEnds.End0,v, DatumExtentType.Model)
    i.SetDatumExtentType(DatumEnds.End0,v, DatumExtentType.ViewSpecific)
#    i.SetDatumExtentType(DatumEnds.End1,v, DatumExtentType.Model)
    i.SetDatumExtentType(DatumEnds.End1,v, DatumExtentType.ViewSpecific)
OUT = v
This is excelent wired_wrong!!!
confirmed working for GRID on floor plan drawings.
But why doesn’t it work on elevation / section drawing?
The python node generate this error:
File “”, line 20, in
Exception: The datum plane cannot be visible in the view.
Parameter name: view
Do you still get this error
This might be as a result of your view settings. Something is being hidden that uses the datumplane.
I get the same error
Any help?
I think if any grid / level is outside of the view, then you will get the aforementioned error.
