Hi Guys
I’m having a problem using python for switch.join
It works well if everything is done before running but every time I paint the beams and run again it can not be updated. Can someone help me re-edit python
For more help see my video
href="//cdck-file-uploads-global.s3.dualstack.us-west-2.amazonaws.com/business6/uploads/dynamobim/original/3X/8/0/80c6f7a27dab400ced275bbde86a54a32779092d.dyn">J.1.3.Switch Joint all in.dyn (7.5 KB) Project2.rvt (2.6 MB)
clr.AddReference(“RevitAPI”)
dataEnteringNode = IN
for A in elementA:
for B in elementB:
try:
result = Autodesk.Revit.DB.JoinGeometryUtils.SwitchJoinOrder(doc,A,B)
result.append(result)
except:
pass
OUT = results
My idea is to add the Unjoin python fragment then Joit and finally the switchjoin
But due to the low python level I do not know how to combine them into a python file
python for Unjoint
clr.ImportExtensions(Revit.Elements) #The inputs to this node will be stored as a list in the IN variables.
for A in elementA:
for B in elementB:
try:
result = Autodesk.Revit.DB.JoinGeometryUtils.UnjoinGeometry(doc,A,B)
except:
pass
TransactionManager.Instance.TransactionTaskDone() #Assign your output to the OUT variable.
OUT = results
for A in elementA:
for B in elementB:
try:
result = Autodesk.Revit.DB.JoinGeometryUtils.JoinGeometry(doc,A,B)
except:
pass
OUT = results
Sorry, I do not have Revit 2018 so I cannot test with your project file. As for the python, I am not sure I understand what you want. You want to just combine the three scripts in that order, Unjoin, Join, SwitchJoinOrder? Wouldn’t it be just this:
elementA = UnwrapElement(IN[0])
elementB = UnwrapElement(IN[1])
results = []
#Unjoin
for A in elementA:
for B in elementB:
try:
except:
pass
#Join
for A in elementA:
for B in elementB:
try:
except:
pass
#Switch Join
for A in elementA:
for B in elementB:
try:
except:
pass
OUT = results
I can’t test this at the moment but if this isn’t what you want, could you try clarifying it, maybe with a drawing or explanation of what you want as the outcome?
Thanh @kennyb6 for reply:
I already try this code but error "Warning: IronPythonEvaluator.EvaluateIronPythonScript operation failed.
unexpected token ‘’ @kennyb6 I have trouble when use switch.Join for intersection handling column-beam-floor. It does not update when I add drawing a new element
Please see my video in page #1
I need help from you
That error was because you were using " in the import instead of ’
clr.AddReference('RevitAPI')
results = []
#Unjoin
for A in elementA:
for B in elementB:
try:
except:
pass
#Join
for A in elementA:
for B in elementB:
try:
except:
pass
#Switch Join
for A in elementA:
for B in elementB:
try:
except:
pass
OUT = results
