Sweep profile family
Hello Dynamo Friends :slight_smile:
I want to use a profile family to sweep a solid and later build a loadable family.
To get the geometry of the profile I use this code:
famDoc = doc.EditFamily(family)
famCollector = FilteredElementCollector(famDoc)
sketch = famCollector.OfClass(Sketch)
for i in sketch:
	cArray = list(i.Profile)
cArray[:] = [[Revit.GeometryConversion.RevitToProtoCurve.ToProtoType(y, True ) for y in x] for x in cArray]
OUT = cArray
The result is that the sweep is not at my path, so I think there is a problem about family coordinates of the profile and my path coordinates?
Later I have to make a plane out of my curves and rotate the profile to plane normal, but first step is to get my profile on the path somehow.
Appreciate any help, kind regards!
Profile:
Ok, I´m getting there, moved the profile to all curve start ponts:
Can you post the files (rvt/rfa and dyn) to work with this? Otherwise we are kinda guessing at the solution.
One thought: build a new profile family, load it into the document, and change the sweep’s profile to the newly loaded family.
Aaaand now I´m failing at placing the families.
I just tried to place them at the startpoints of the curves, this does not work because the families have obviously a different base point.
Do I have to create the families with a specific basepoint in first place?
blue=dyn geometry, grey=revit family
I’m out of guesses. Can you post a file or two to reproduce the issue?
dyn and rvt attached.
Thanks for your help jacob!
SweepMe.rvt (6.0 MB)
SweepAtCurve.dyn (80.8 KB)
Are there other nodes for family creation out there, or which API methods can I use?
Not entirely sure I know what you’re after, but this seems to be what you want, and as an added benefit you get a family which can be edited natively.
Generate Sweep Families
Sweep Family By Curves and Profile.dyn (16.8 KB)
:open_mouth:
Ok, I thought saving a geometry object to a family and living with a non editable thing is the only option I have.
Did not know that I can just work in a new family and create geometry with revit sweeping, etc…
That´s amazing! Thanks you for the code Jacob :slight_smile:
