I have done a search on this forum and others, but I could not find the solution I need, I have succeeded in this program but has a glitch, hope someone can help fix this issue.
What I am trying to Do?
- Select 3D Polyline from CAD instance (Polylines and Arcs etc.)
- Select Profile
- Sweep the profile along the polyline
Glitch:
Sweep does not keep the plane of sweep parallel to XY plane, at the start of each segment plane get rotated, please see attached Image. In plan view, the width of sweep should remain same for each segment.
What this program can do,
- Create roads
- Sidewalks, Curbs
- Earthing Strip
- Any linear element which has up and downs, twist, and turns
Attached Program and image showing problem
Sweep-3D-Polyline.dyn (47.8 KB)
