Hi!
I am trying to ad point at the not parallel edges of a slab. I’ve selected the face and made a definition in Dynamo, but the points from slated edge doesn’t follow the line. how should I solve this? can anyone helpme?
Hi!
Still searching for a solution and not found yet…
Why not to get perimeter curves of face and divide the required edge.
Hi @GABRIEL.PLESEA,
This is because the surface you see in Dynamo is actually a Trimmed Surface. This is a Grasshopper for a Surface which has been sliced of modified. The Bounds (Parameters) of the surface lie outside the surface.
A way to work around this kind of problems is the following:
Extract the Perimeter Curves and Find the curves opposite from eachother And create points using Curve.PointAtParameter (Also what @ingenieroahmad is suggesting :))
Thanks a lot!
I see now how I should proceed!
