Hello dear experts,
By accident I bumped onto a fact that surfaces in dynamo are like classes in revit API. It seems that they have a lot of hidden properties and methods which you can not access with a dynamo user interface.
For instance I found that a surface object contain an attribute that is called Faces. Faces have an attribute Loops and these loops have a method that defines if a loop is external or internal
Therefore, I understood that somewhere should be information about Dynamo/Autodesk geometry like we have a website for Revit API.
In another words, can you please advise where I can get all the info about the dynamo’s geometry API
