Surface is not generated when connecting from Dynamo_NurbsCurve.ByContralPoints to Surface.ByLoft
Translated by moderator. Original post below the line.
I am learning Dynamo using this site as a reference.
・Revit Peeler: ダイナモ白熱教室(5)~点
・Revit Peeler: ダイナモ白熱教室(6)~Cos
・Revit Peeler: ダイナモ白熱教室(7)~点-線-面
I would like to make a point into a surface using a list of X and Y and cosine curves and Z vectors.
I can’t do it well.
Get X and Y from List with point.Bycoordinates.node
Get cosine curve from List with point.Bycoordinates. node
I got the Z vector from List with Vector.ByCoordinates node.
I connected them from List.Map to NurbsCurve.ByContralPoints and connected them to Surface.ByLoft.
An error occurs and it doesn’t work. Please tell me what should I do.
Original post below.
こちらのサイトを参考にDynamoを学んでいるものです。
XとYとコサインカーブとZベクトルのリストを使用して、点を面にしたいと思っていますが
うまくできません。
ListからXとYをpoint.Bycoordinates.ノードで取得
Listからコサインカーブをpoint.Bycoordinates.ノードで取得
ListからZベクトルをVector.ByCoordinatesノードで取得しました。
それらをList.MapからNurbsCurve.ByContralPointsへ繋げSurface.ByLoftに接続しましたが
エラーが出てしまいうまくいきません。どうすればいいのか教えてください。
@Azu the official forum language is English. This is a requirement for search to work. Please use an online translation tool to translate all posts in the future as I did in the edit of your post.
My apologies. I did not understand.
I see that I should post in English. Thanks for Edit.
