Surface from Solid (Footprint)
Hi everyone,
Im currently starting to learn Dynamo for Civil3D! I had a question regarding creating a surface with offsets from a 3D Solid object. I also want to have custom inputs to offset the surface from sideways and downwards. Added a picture on how its suppost to become after creation
Since new users can’t upload files here, i added the example file to filemail where you can download it.
hi
cordially
christian.stan
And thank you so much for the reply. im testing it right now. For some reason i cant find the two first nodes. is it in a pack or something?
Hi, I don’t have Civil, only Revit. I thought there were these similar nodes. Mr. @jacob.small, if he’s around, should be able to answer you.
Sorry
Sincerely
Christian.stan
Select Object and Object.Geometry might get you started. I recommend going though the primer skipping only the Revit section, as it will help with these types of questions.
