So what i am looking for? monocle says nothing? 2 weeks ago the script run well!
OOTB i can´t find
KR
Andreas
It’s an OOTB node from a further release than you are in. ![]()
so OOTB means “Out Of The Box” Node - how do i deal with that? who is Jeeves?
Yes - OOTB means out of the box, means it’s a part of Dynamo Core.
To get this node you will have to upgrade to a newer version of Dynamo. Dynamo 2.3 should have the node, which means from a Revit perspective you will need Revit 2020.2 or newer. If you are in a mixed environment (not recommended) you will need to upgrade to 2020.2 to use a graph that leverages this node.
oh… the problem is i use Revit 2018.3.3. with 2.0.4. Dynamo
can i just copy this node?
Hi JacobSmall!
How can make for many surfaces subtraction many surface?
Thank!
Can you create a new topic!
Hi, this new topic
[How does Surface.differences for many surfaces]
Help me,
Thanks!
