Hello guys ,
I wrote down a dynamo script to put supports on all pipes in my model but the problem is that the reference level for all supports disappear here is a picture for normal support and another for support by dynamo
Hi
You have assigned the pipes without specifying the “Level Reference”. You probably used the “FamilyInstanceByPoint” node.
Please try with “FamilyInstance.ByPointandLevel”.
Thank you , it worked
Hi @eng.elfeky
If your issue is resolved, mark the issue as resolved so that users with the same issue can quickly access the answer.
