Sum duct with duct fitting
Hi, I am new to dynamo so this might be a stupid question.
I need to create a script that allows me to sum ducts and duct fittings according to the proper size.
Anyone have an idea about to do?
Welcome to the forums.
You’ll need to provide more information and show us what you’ve tried so far. What value are you trying to sum up? Is the “proper” size different from the modeled size? Search for topics related to collecting and grouping elements and see where you get. You should also work through the Dynamo Primer to learn the basics and get familiar with some common workflows.
Hi Nick,
Thanks for the quick reaply
I started by filtering the ducts and duct fittings.
Within each category, I filtered by the type of duct, then by whether or not there was insulation and finally by size.
The size of the ducts is the same as in the model
Can you share a screenshot of what that looks like so far and what you’re still wanting to accomplish? Be sure to zoom in so everything is legible and pin your node preview bubbles so we can see the data you’re working with.
