I have a list with sublist and need to count the sublists that are the same.
Cant figure it out?
Use the List.Count node and change the Levels. Here is information on Lists @ Levels http://dynamobim.org/introducing-listlevel-working-with-lists-made-easier/
Maybe I explained it wrong.
List 1 and 2 has the same value in index 0 to 3 so instead I need 1 list with those indexes.
If I am understanding correctly, you want to get rid of duplicate sublists? List.UniqueItems will give you a list of only the unique sublists in your list.
Thank you. That was easy
One more question.
How can I count the number of all list that I just combined into unique lists?
Not sure I explained this correct. Does it make sense?
What i want is to count how many of each unique item there is?
Do you mean to count how many sublists there were for each unique sublist?
Exactly!
Thank you. I will try that.
