Stuck with placing ceiling lights
I am trying to place ceilings lights on coordinates imported from CAD file using (Package Genius loci and node CAD block). Through this node I am getting coordinates. However When I am placing lights its only placing family on Level o. I tried importing .dwg in next level even its placing lights on level 0. I tried changing elevation (Point. Z value) its showing points in dynamo (Creating double points in both levels) however only placing families in level 0 not in level 1. Please help me out I am really stuck. I am attaching my file
Placing Electrical Lights - Face.dyn (19.7 KB)
Hi @sbukhari.cem18nit,
Use instead the FamilyInstance.ByPointAndLevel node to place the lights.
@Alban_de_Chasteigner Still it is not working. Although I am getting points in Level 1 but families placement is only happening in Level 0.
Probably a problem with your family if the dynamo points are right.
Would you suggest somthing more? I am attaching the family file.
Lighting-Flush_Mount-Tech_Lighting-Crest_12.rfa (420 KB)
@Alban_de_Chasteigner I have also tried placing family by coordinates. I guess there is issue in family because when I am placing columns or other families it is working properly. Can you suggest somthing.
