Structure of nodes getting lost in newer version of Dynamo
I want to try the Dynamo script I made in different versions of dynamo and Revit, but everytime I import it to a newer version of Dynamo, the whloe structure and grouping of the nodes is missing (as you can see in the picutres). The code is still running, but its very annyoing to sort them again. Does anyone knows how to prevent this? I’m working with 2.10.1 and 2.3.0 image
@klara.steinMZ7FJ ,
i had this issue several times…
sometimes it worked restart revit.
you can do Block to Code … i hope there will be one day Code to Block
or doing it the hard way move block by block, or rebuild the script via screenshoot… :wink:
