StructuralFraming.BeamByCurve Archi-lab node
Hey Guys, I’m trying to draw structural framings using lists of curves…
but Archi-lab node is having trouble…
K-006
I cant understand what this means…
have you tried the OOTB node ? in Revit - Element - Structural Framing- BeamByCurve ?
Thanks khuzaimah,
what is “OOTB node”?
are you saying this?
K-007
I already tried it…
but the result was so bad…
K-009
someone has rotated, someone has disappeard.
I already asked this so many time:sweat_smile:
but many of users recommend using adaptivecomponent.by points
however, I have to make structural framing… I
we cannot make structural framings by using adaptivecomponent.by points, right?
so I’m finding another way to make structural framing…
Tunnel Structural Framings_V.0.0.18 By Jicaprio_Import Families by path that their length has defined by Excel AdaptiveComponents.dyn (275.6 KB)Linings only_Koreanname1.zip.txt (3.5 MB)
Civil Report_안성방향 V0.0.11.xlsx (686.1 KB)
try the line.direction node to see if all lines are pointing in the same direction.
Thanks, Marcel
I checked line.direction, but the line I drew is curve.
maybe line.direction node is only for direct line…
OOTB mean out of the box, in other word the built-in node in dynamo library, i just notice that you have 230 curve with 229 type, yo have to make the equal.
and if you use the OOTB node what is the message you got?
@Mu_Jica - can you post the full data set (rvt, dyn, etc)? It’s hard to see what/where the issue lies. There are a nearly infinite possibilities and we’re stuck guessing otherwise. I’d you can’t post the full data set, build a fake one that matches the problems you’re seeing.
You have asked about this a few times so I’ll step up to help out.
Oh, I did not know that I would ask you again for help.
Your advice has been a great help, and I have tried to do it, but there are still some areas that I have not solved so I can create a topic again.
The files are so large to upload,
I uploaded in googledrive.
https://drive.google.com/drive/folders/1UP5ymSeS-br7Sajy8Cb52GCpOjXP1_ls?usp=sharing
