Has anyone tried to export Tekla values from beams in to dynamo. I’ve set all the values to one in the project environment but for whatever reason it show a random number in dynamo. Is this a conversion problem by any chance? Please see below.
Excuse one of parameters showing moment as a force it’s been spotted already.
What seems to be happening is the kilonewtons value is being transferred between kilo newtons to feet for some weird reason(to Feet and see attached). But as a note the revit database saves all values in imperial units but the values you see( “As value String”) are how you decided to show units via project units.
As you can see the value in the revit data base is similar to a metre to feet conversion of units but if you can access the “As Value String” you can get the direct value.
Is there a 2016 version of this? I’ve downloaded the package from this link, but there doesn’t appear to run exe. file to install it and there nothing in the readme to tell you what to do.
