Looking to create a Python to give Bool results for Start and End if Join is Allowed. true/false
I found a Python to set to Allow or Disallow, now looking to create a filter for these items.
Fairly new to Python looking for some help to give me Bool values.
Import RevitAPI
clr.AddReference(“RevitAPI”)
Import DocumentManager and TransactionManager
Unwrap
input = UnwrapElement( IN[0] )
elements =
#force input into list
try:
for e in input:
if e.Category.Name == “Structural Framing”:
elements.append(e)
except:
if input.Category.Name == “Structural Framing”:
elements.append(input)
Start Transaction
for e in elements:
Autodesk.Revit.DB.Structure.StructuralFramingUtils.IsJoinAllowedAtEnd(e, 0)
Autodesk.Revit.DB.Structure.StructuralFramingUtils.IsJoinAllowedAtEnd(e, 1)
End Transaction
Wrap
OUT = elements
Please make sure you paste formatted code with the preformatted text option (</> in the formatting toolbar).
You have the method for getting the boolean value. Now you just have to do something depending on whether the method returns true or false. If it’s as simple as creating two lists, then you just need to do that and append each element that meets the condition (or doesn’t).
hi
import sys
clr.AddReference('RevitAPI')
from Autodesk.Revit.DB.Structure import StructuralFramingUtils as sfu
elts=UnwrapElement(IN[0])
stock=[]
for e in elts:
stock.append([sfu.IsJoinAllowedAtEnd(e,0),sfu.IsJoinAllowedAtEnd(e,1)])
OUT = stock
cordially
christian.stan
Christian,
This works thank you, I was able to modify what you gave me to understand more of what you did. Once I saw it written out it helps me understand better what I was missing. I may not go my route will most likely use yours, but will not know until I start developing the graph more.
Below is a slight modification, just to separate out what was “start” or “end”
import sys
import sys
start=[]
for e in elts:
start.append([sfu.IsJoinAllowedAtEnd(e,0)])
end=[]
for e in elts:
end.append([sfu.IsJoinAllowedAtEnd(e,1)])
OUT = start, end
Nick,
Thank you for pointing out the </> in formatting tool. I will start using that from here on out.
Hi, to avoid adding a list of lists with append, you can hide the [ ]
start.append(sfu.IsJoinAllowedAtEnd(e,0))
Sincerely
christian.stan
