Hi, I made a code to place structural framings. To get the full length without cutback I used Revitframe.disallowjoin and set value node. but still my framings have shorten length than the curves(input) I’ve tried to change the values but this approach didn’t work. Is there any suggestion?
Hi, @robert12546358
Thank you for your suggestion.
I’ve searched for the node but couldn’t find exact same one.
Do I need to download any packages?
Or can I use the one in the picture?
Now I’m testing my script with the Element.SetParameterByName node.
“Rhythm” package download.
@robert12546358
[The parameter is read-only]
It happened in same way when I tried to adjust the cutback values through setvalue node. So, I used Dissallowjoin node from Structural Design package.
