I trimmed line by using Curve.Project node(Base geometry). This was successful and all the trimmed lines’ length were correct. But when I made structural framing with these lines(curves), there were gaps between the solid that I used for trimming. I couldn’t find what I missed,please give me any advice.
Hi, Those X marks are lighting fixtures and I changed these to solids from bounding box(Because one lighting fixture contains two solids). So, its not a flat surface.
Thank you for your advice. I could change the value of cut length to 0.0.
But the cut length is shorter than the calculated length. Is there any ways to change all the Cut Length values to the Length that I highlighted at once?
I lack the skills to be able to answer you unfortunately (I only started recently, a year ago I started revit, and since February dynamo, with the last month more on a regular basis)
I still have a lot of dark areas (for one as for the other) and a big margin of progress.
Hi, Thank you for your solution. I could see that I’m reaching to my goal.
I used the DisallowJoinAtEnd node that you used but when I put 19 elements as inputs it only returns 2 result. do I need to put different numbers for the End(input)?
