Hi team,
Im trying to make a script with a node Geometry.WindowDoorOpeningCharacteristics to place some trimmer bars around a window opening, however this is driving me crazy.
for some reason the node is not working properly.
any idea?
Hi seems you feed in a string and not opening element [windows,doors]
i got confused, the parameters should be in string but i dont know why is not working with the element.
Cheers
if you hover over the nodes input, you can see what is expect
interesting @sovitek i thought should be the parameters of the host, ill give it a go tonight.
i have been doing some research online and what i want to do is this:https://www.youtube.com/watch?v=b6kfPhlDJuY
not necessary from dynamo player. i don’t mind to do it from dynamo. any idea where i can see something similar to this to guide myself ?
Cheers
Finally, it’s working. This node only accepts window or door families by default (like the ones included in Revit). I was using a generic family. I edited that and only changed it to the Windows category; it never worked with that one.
Thanks for the tip
