How to put a door or window object on the wall?
HI,
I’m new to Dynamo.
I know to build a wall, but do not know how to put a door or window approach.
how does the put a door or window.
Thank you.
Check out this discussion…
http://dynamobim.com/forums/topic/place-doors-windows/
Spring nodes has a node that will handle windows and doors:
2015-10-26_16-05-34
Thanks for your ~
Every time I try the above example Revit Crashes. I tried with 2016 and 2017.
Have you tried running the graph in manual mode? Most likely the graph is getting stuck in a perpetual loop because of the “Select Model Element” node, which updates every time the selected element in the project updates.
Thank Dimitar,
In deed when set to manual Mode it works nicely.
Best,
Jawad
