I am trying to retrieve the Structural Deck used in a composite floor, the actual type of it.
I used nodes from Genius Loci and Clockwork, but no luck. Any idea. Thanks in advance.
You have to go 1 step further, The CompountStructureLayer contains an DeckProfileId. That you can use to get the Deckprofile type. With the pythonscript below you can put the CompountStructureLayers in the IN[0] variable. It will return Null if there is no profile.
clr.AddReference('System')
clr.AddReference("System.IO")
from System import *
from System.Reflection import *
from System.IO import *
#Import the Revit Services
app = uiapp.Application
#Import the Revit Nodes
#Import the Revit API
clr.AddReference("RevitAPI")
#Import math functions
import math
def tolist(obj1):
if hasattr(obj1,"__iter__"):
return obj1
return [obj1]
#Define Input (IN)
compountLayers = tolist(IN[0])
output = []
# Start Transaction
for layer in compountLayers:
id = layer.DeckProfileId
element = doc.GetElement(id)
output.append(element)
#End Transaction
#Define Output (OUT)
OUT = output
