Structural Column Location
I am trying to get dynamo to provide the X,Y,Z of the start and end nodes of each column. To do so, I have realized that columns are not quite so user-friendly as framing is.
So it looks like I have to use Clockwork to get Element.Location for the columns. However, when I do so, the Z value for each location point is equal to Zero ft, no matter how high or what offset I put on the column (See attached image). Is this the way it is supposed to work?
I have created a functional workaround that involves pulling the Base Level of each column, pulling the location of each level, then correcting the Z value by adding the Level Location, but i’d rather do it the right way if there is such a thing.
Thoughts?
Column Location Issue
As an easier workaround you could pick the Z-values from the Max/Min values of a element boundingbox.
If you set your columns’ “Column Style” inside the Revit UI to “Slanted - End Point Driven”, you will be able to read their location curve:
2014-12-22_120906
2014-12-22_121057
You can alternatively set the “Column Style” with the Element.SetParameterByName node, by feeding an integer:
2014-12-22_121347
My first try was by changing the column style to “slanted-end point driven” and it worked fine except that I got a message to ungroup all columns. Seems that changing the column style cannot be done for groups.I also tried the Bounding box method, but it gives the “bounding box” of the column, not the center, so a formula to get the center is probably needed.
It’s good enough, but maybe there is a better way. ideas ?
Capture - column location mark - bounding box
Capture-column location - curve point
You could try implementing some DS code for the BB method:
2015-01-05_161228
Or you can use the X and Y from Element.Location node and just extract the Z-value from the bounding box method. Dimitars DS-code is way cooler though… :slight_smile:
Works perfectly, thanks.
Capture-COLUMN LOCATION
Has there been a node for column location that I haven’t seen?
Hi @Timon
Element.Location from clockwork package is one of the possible way to get column location.
Hi Kulkul, my current process uses that. But for typical vertical columns I have to generate the column location. Here’s my typical process:
@Timon Another possible way:
And that’s why we ask these kinds of question. I knew there had to be another solution, however it’s not working on my computer:
@Timon try using family types and get elements.
There must be a conflict with another package on my computer. I’m getting the same “empty lists” when I duplicate your script verbatim
Try to change the columns to slanted…
kulkul-
I’m with Timon on this - what you showed only will work if the columns are slanted column. It is possible to change the columns to slanted, pull the locations and/or curves, then switch back to vertical columns, but that taxes the system pretty good if you have more than a handful of columns (note the conversation in the post Einar referenced)
Timon-
Try this bit of Python Script (it’s essentially a modification of element .location + the top and bottom offset calculations)
import math
clr.AddReference('RevitAPI')
clr.AddReference("DSCoreNodes")
from DSCore import*
columnz = UnwrapElement(IN[0])
projectElevBool = IN[1]
startpointlist = list()
endpointlist = list()
rotations = list()
curves = list()
columnstyle=list()
for col in columnz:
	paramlist = col.Parameters
	rotparam = BuiltInParameter.STRUCTURAL_BEND_DIR_ANGLE
	colstyle=-1
	baselevel = -1
	toplevel=-1
	baseoff ='nada'
	topoff = 'nada'
	for p in paramlist:
		if p.Definition.Name =='Column Style':
			colstyle = col.get_Parameter(p.Definition).AsInteger()
		if p.Definition.Name =='Base Level':
			baselevel= doc.GetElement(col.get_Parameter(p.Definition).AsElementId())
		if p.Definition.Name =='Base Offset':
			baseoff= col.get_Parameter(p.Definition).AsDouble()
		if p.Definition.Name =='Top Level':
			toplevel= doc.GetElement(col.get_Parameter(p.Definition).AsElementId())
		if p.Definition.Name =='Top Offset':
			topoff= col.get_Parameter(p.Definition).AsDouble()
	if projectElevBool == True:
		basel = baselevel.ProjectElevation
		topel = toplevel.ProjectElevation
		basel = baselevel.Elevation
		topel = toplevel.Elevation
	if colstyle ==0:
		columnloc =col.Location.Point
		rotations.append(math.degrees(col.Location.Rotation))
		#rotations.append(col.Location.Rotation)
		newXYZbottom =XYZ(columnloc.X,columnloc.Y,basel + baseoff)
		newXYZTop =XYZ(columnloc.X,columnloc.Y,topel + topoff)
		startpointlist.append(newXYZbottom.ToPoint())
		endpointlist.append(newXYZTop.ToPoint())
		curves.append(Line.ByStartPointEndPoint(newXYZbottom.ToPoint(),newXYZTop.ToPoint()))
		columnstyle.append(0)
	elif colstyle ==1 or colstyle ==2:
		startpointlist.append(col.Location.Curve.GetEndPoint(0).ToPoint())
		endpointlist.append(col.Location.Curve.GetEndPoint(1).ToPoint())
		rotations.append(math.degrees(col.get_Parameter(rotparam).AsDouble()))
		#rotations.append(col.get_Parameter(rotparam).AsDouble())
		curves.append(col.Location.Curve.ToProtoType())
		columnstyle.append(2)
		rotations.append(-1*math.degrees(col.Location.Rotation))
OUT = (startpointlist,endpointlist,curves,rotations,columnstyle)
@Ben_Osborne… you hit the nail on the head. Vertical columns “location” is actually just a point. That’s where you started this conversation a while back. The python you have written out looks quite like the image I posted in Reply 9. Have you published that in a package?
@kulkul. I was so excited thinking that you were working with vertical columns.
Thanks!
It’s basically the same as what you showed, except your Dyn left out any accounting for offsets from the Base Level or Top Level - in my experience bottom of column is usually offset below the base level of the building :wink:
@Ben_Osborne Oh I just realized I posted the simplified version…=)
