I’m working on code. which place tags to all structural bema in series order. I tried the below code as per some references in the forum. But still, I’m not able to provide series order tags,
Help me to solve this code.
I want tags in series order.
Dynamo code:
Beamm Tag Series-TEST-R01.dyn (184.3 KB)
You might replace process of start and end point of beams locations with only point in the middle of those locations and sort them with Y first then sort with X.
Are you trying to make some sort of erection plan? This is an interesting problem as Revit assigns element IDs in random order.
Thank you for your reply, If u don’t mind can I get a map for reference.
only I’m trying to arrange tags for existing beams in plans.
Thank you very much it’s working…
But I’m getting in reverse order, not like yours, can u check once
Put a (Reverse List) Node After each sort nodes in the script to solve Y Direction sort.
You might Sort also after Y by X values ( Same scenario ) and use reverse if you need.
Thankyou very Much…Working fine…
Small Problem in code, there is some misarrangement in numbering.
