String to Spec Type
Buongiorno a tutti,
nel creare dei parametri condivisi da un file excel non riesco a convertire una lista di stringhe in Spec Type.
Avete qualche suggerimento in merito?
Grazie
EDIT : Translated by Moderation (English forum)
Good morning, everyone,
in creating shared parameters from an excel file I cannot convert a list of strings to Spec Type.
Do you have any suggestions on this?
This code was made for GroupTypes but there wouldn’t be much to change for Spectype, Give it a go :slight_smile:
Hint for you*
# Collect the parameter groups and convert them to a string list
parameter_groups_enum = System.Enum.GetValues(BuiltInParameterGroup)
parameter_groups = [System.Enum.GetName(BuiltInParameterGroup, group) for group in parameter_groups_enum]
here is a solution with Python
the input is a flat list of the Name of Parameter Type (Spec Type) :
  • in English
    or
  • in Revit Current language
Python code (compatible to all engines)
import sys
import System
clr.AddReference("RevitAPI")
def toList(x):
    if isinstance(x, list):
        return x
    elif hasattr(x, "GetType") and x.GetType().GetInterface("IEnumerable") is not None:
        return x
    else :
        return [x]
lst_specType_Name = toList(IN[0])
invalid_forgeTypeId = ForgeTypeId()
dict_forgeTypeId = {}
lst_specTypeId_class = [clr.GetClrType(SpecTypeId),
                        clr.GetClrType(SpecTypeId.Boolean),
                        clr.GetClrType(SpecTypeId.Int),
                        clr.GetClrType(SpecTypeId.String)]
for specTypeId_class in lst_specTypeId_class :
    prop_infos = specTypeId_class.GetProperties()
    # get the Name of SpecType and put it in a dictionary {SpecType Name : SpecType }
    dict_tempA_forgeTypeId = {p.Name : p.GetGetMethod().Invoke(None, None) for p in prop_infos}
    # get the LabelForSpec and put it in a dictionary {label : SpecType }
    dict_tempB_forgeTypeId = {}
    for key_, value_ in dict_tempA_forgeTypeId.items() :
        try:
            dict_tempB_forgeTypeId[LabelUtils.GetLabelForSpec(value_)] = value_
        except Exception as ex:
            print(ex)
    # merge dicts in  main dict
    dict_forgeTypeId = dict(dict_forgeTypeId, **dict_tempA_forgeTypeId)
    dict_forgeTypeId = dict(dict_forgeTypeId, **dict_tempB_forgeTypeId)
# get DB.SpecTypeId by input Name
lst_db_specTypeId = [dict_forgeTypeId.get(txt_value, invalid_forgeTypeId) for txt_value in lst_specType_Name]
# convert to Dynamo Revit.Elements.SpecType
OUT = [Revit.Elements.SpecType.ByTypeId(v.TypeId) for v in lst_db_specTypeId]
