String Replace - Sequence of Numbers
Trying to shorten a list by removing part of the list. (I just want it to save Revision 1 thru whatever not Seq. 2 - Revision 1 thru whatever)
I can seem to make this easy for me.
Thanks in advance
Hi @jarod.tulanowski,
If you want a general script with substitution and/or replacement, please check this script substitute_pattern.dyn (6.0 KB)
-biboy
That worked perfect!!! Thank you for the assist!
