So Dynamo decided to do this today: Can anyone help me understand why, where, or what I need to set in the file to keep it from doing things like this? There is not data coming into this node with this amount of significant figures. Is it a Revit units problem? Weird.
Or use a code block:
String.Replace(str, “.000000”.””)
I used a string separate node to cutoff everything after the decimal. @Jonathan.Olesen, what is your understanding as to why Dynamo does this? Absent any other input that would add the extra decimal places I’m not seeing how this cannot be viewed as a slight oversight in the application.
@Cody_Winchester It’s working for me
It’s the difference between a number and an integer.
As @salvatoredragotta said used Ceiling or Floor.
