Dynamo4AS creates Straight Beam (StraightBeam.ByStartPointEndPoint Node) in wrong vOrientation of the beam cross-section for the first time I run the script. Making the minor changes cause recalculation of the script, than cross-section will be oriented correctly.
Simple script here:
- run script
- check section orientation (wrong)
- change beam length
- run script
- check section orientation (correct).
Is there a way to get a correctly oriented profile when I first run the script?
test_beam3.dyn (8.1 KB)
