Hi All , I want to cope/notch the steel beams, i tried to look for a dynamo node and I found Family instance.AddCoping which does the job for a single element, may i know if there is node to do it for multiple elements at once? Thanks in advance
Adjust the lacing and list levels and it should work fine.
Thanks Jacob, it worked
