Hi devlopers!
I’m creating a workflow to copy a set of template views, organise them appropriately, (check, nailed it!) and also to copy a set of template sheets and insert the respective views onto those new sheets. However the project is Revit 21 and Dynamo 2.6 (my first time using this version) and I have noticed that there have been some updates to the syntax and the the create empty sheet from steam nodes needs to be updated accordingly. I took a couple cracks at it but was unable to solve all the issues.
Hopefully there’s a helpful soul out there who is familiar with the changes and can help me sort this node out!
Or even better if the Steam Nodes developer sees this and can update what’s necessary.
I’ve attached the screenshot of inside the broken node, as well as copied the python code for reference/adjustment.
#python nodes in dynamo 1.0
#proposed by Julien Benoit @jbenoit44
#http://aecuandme.wordpress.com/
#Credits for Traceback:
# Copyright(c) 2015, Konrad K Sobon
# @arch_laboratory, http://archi-lab.net
# Import geometry conversion extension methods
# Import RevitAPI
clr.AddReference("RevitAPI")
import sys
pyt_path = r'C:\Program Files (x86)\IronPython 2.7\Lib'
sys.path.append(pyt_path)
app = uiapp.Application
elt = []
names=[]
numbers=[]
sheets=[]
for i in IN[0]:
elt.append(UnwrapElement(i).Id)
for i in IN[1]:
names.append(UnwrapElement(i))
for i in IN[2]:
numbers.append(UnwrapElement(i))
# Start Transaction
for i,n,u in zip(elt,names,numbers):
try:
errorReport = None
a=ViewSheet.Create(doc,i)
a.ViewName=n
a.SheetNumber=u
sheets.append(a.ToDSType(False))
except:
# if error accurs anywhere in the process catch it
import traceback
errorReport = traceback.format_exc()
# End Transaction
#Assign your output to the OUT variable
if errorReport == None:
OUT = sheets
OUT = errorReport,sheets
Thanks in advance!
