Hello All,
I am using Springs.Feet2Fraction node and I am having some trouble with it. The node is adding an quotation mark in front of the inches part, for example: (1’ - “8 3/4”). I was wondering if there is a way to get rid of the extra by adding a line of code to the Node to remove this extra quotation mark. Thanks.
Can’t say I’ve seen this behavior - can you post a graph showing the reproducible case?
Hi Jacob,
Thanks for the response, The forum wont let upload or copy any images. Thanks
A Onedrive, google drive, box, Dropbox, etc. link should work. I’ll try to ‘bump’ your privileges from my moderator account later today either way.
The Image I was able to post just came up.
Which version of Revit?
Can you expand the results of the GetParameterValueByName node?
