Can someone help me figure out why I can’t get this node to list any info? I’ve found videos of this node working with the same setup but mine wont report anything. I’ve tried different error reports as well but get the same output ![]()
Pop open the custom node, copy out the contents, and try using it in the workspace environment and the error should surface.
try commenting out eveything after line 67 and set the output to be the variable named in line 67.
Repeat this for line 68, 69… etc. until the error becomes a bit more apparently.
Hi, try updating to the latest version of springs ![]()
