Hi all,
I am using Spring. Form. ByGeomegtry to import my solid pipes into family.
But some of the pipes are not importing.
It looks fine in Dynamo. All elements are solid.
In Spring. Form. ByGeometry, it said “Traceback most recent call last”
I suspect you’re working in Revit 2018? Something about the SAT importer changed in 2018 and now some solids that worked fine before, fail to import. You can verify this by exporting your solids with the export to sat node and then manually importing them in Revit.
Thank you for the reply.
Yes, I am working in Revit 2018.
The SAT export works fine, but it took too long to import in family.
Thanks.
