is there any way to extract the element a spot elevation is attached to. i can get the spot elevations but i was wondering if this could be a automatic process?
thanks
Hi @jschnare,
It’s not that straight forward, but you can get the “host” (a reference actually) like this:
Python:
#Import the Revit API
clr.AddReference('RevitAPI')
#Import DocumentManager and TransactionManager
#Reference the active Document and application
#Start scripting here:
sd = UnwrapElement(IN[0])
elems = []
for i in sd:
ref = i.References #Get the Spot Dimension reference. Returns a Reference Array
for j in ref:
elemid = j.ElementId #Iterate the Reference Array and use the ElementId property to get the ids
elems.append(doc.GetElement(elemid)) #Use the GetElement() method to get the actual elements
OUT = elems
It will work for other elements that fall in the same category, ofcause, like Spot Slopes and Spot Coordinates:
By altering the code a little bit, you can get a list of reference elements per Spot Dimension you input. Might become handy if you have Spot Dimensions that references more than one element, like a linear dimension :-):
Python:
elems = []
for i in sd:
temp = []
for j in ref:
temp.append(doc.GetElement(elemid)) #Use the GetElement() method to get the actual elements
elems.append(temp)
OUT = elems
@MartinSpence THIS WORKED PERFECTLY, I CANT THANK YOU ENOUGH! MY COMPANY IS PLANNING ON INVESTING IN PYTHON TRAINING FOR THIS REASON.
THANKS
Cool!
Glad I could help
