Hi! Why am I getting the following error?:
“Warning: IronPythonEvaluator.EvaluateIronPythonScript operation failed.
Traceback (most recent call last): File “”, line 30, in TypeError: expected Solid, got Solid”
I when executing this code inside dynamo using python script:
import sys
clr.AddReference('RevitAPI')
from Autodesk.Revit.UI.Selection import *
solids = IN[0]
output=[]
for i in solids:
output.append(SolidUtils.SplitVolumes(i))
OUT = output
