Hi all, Im trying to split all rebars over 9000mm. I have the below so far but its not working
Where does the length x>9000 code block go?
You mean by the Split Curve with overlap node?
You need to input DirectionSecondRow too.
what does the error message say? can you post DYN and maybe the Revit file?
Here it is. Issue is its not splitting the rebar so maybe more nodes are needed
https://villaron.sharepoint.com/:u:/s/SBPAdminSales/Edx4ArdzdlJGhn_KKMTaSiIBs4tcbsrVuYI998OkcD7fAA?e=ZmUkxD
SPLIT REBAR.dyn (30.6 KB)
